Hi Aiden, are the planks you used balsa? If so then tissue and dope is one good method among others. It's the method I still prefer, although finishing epoxys are favoured by others.
Have you considered the inside of the hull? This is also vulnerable to damp and water which can swell the planks. I like to use a polyester resin inside my models, it seals and strengthens everything. Old varnish or paint will also seal the wood, but without adding strength.
Enamel sprays are fine, but you might consider the acrylic sprays such as Halfords rattle cans, they also have primer sprays to match.
If your planks aren't balsa, then the tissue etc isn't needed, but still consider the inside.
I hope that helps a little, I expect you'll get some more ideas to think about from others, but the idea is simple, seal everything, take your time, and when you decide on a finish, stick with one type, don't mix different makes.
Chas
