Thank you for your kind comments, Paul. Using epoxy doesn’t in any way reduce the amount of work needed to achieve a good finish, a lot of sanding, usually with wet and dry paper, is required, and epoxy tends to build up on the sandpaper. I hadn’t thought of it as cheating, simply a means to an end, but I understand your point.
We are very fortunate in our part of Australia as regards climate. We are about an hour’s drive south of the Queensland border, right on the coast, and are classed as sub-tropical, which means we do not get the extremely high rainfall and humidity of the tropics, although we can have some quite humid periods. We are now officially in Autumn, although the temperature is still in the mid to high 20s, but cooling down of a night. It is much more comfortable now in my shed, unlike a month or so ago when it was around 36 inside it, too hot to work.
All the best from a warm, and slightly overcast, north east NSW
Peter.
