Posted by Samuel Crowe on 18/10/2017 02:01:13:
Hello,
Thanks again for the fast replies!
I understand the American weight requirement, however as I was using rough plans, I did not scale my boat properly (it is my first ever). I've figured out that since the length of the proper Star 45's is 45 inches, and my hull is 28 inches long its a multiple of roughly 1.6. So since the keel bulb minimum weight is 12 pounds, 12 divided by 1.6 = 7.5 pounds for my boat. That is still very heavy and about $8 British pounds worth of lead. It just feels like the boat needs something smaller. Any other thoughts?
Sincerely, Samuel
For the full size model according to the information in the link, it is not the bulb weight at minimum 12 pounds, that is the entire boat including the keel weight where 12 pounds is the minimum sailing weight. Since your model is about half the length, and when talking weight you are also talking volume, thats about 1/8th the weight. With a ballast ratio of about 50% you are in the 24 oz area total, so a keel weight of about 12oz, maybe 14oz. This fits well with the old Akela design (used to be a free plan years ago) that was 25" long and carried a 12oz weight as well as the modern 25 inch racers (DF65) which carry the same weight.
Shrunken yachts rarely perform up to expectations without there being some modification, usually a longer fin with the same weight to enable sailing in a wider range of conditions. The bulb does need to be a very good hydrodynamic shape, casual lumps cripple performance.
