HOME MADE TOOLS AND JIGS
Home Forums Soapbox HOME MADE TOOLS AND JIGS
  • #21525
    John W E
      @johnwe
      Hi there everyone
      Do you have a favourite home made tool/jig that you always end up going back too to use?
      I made 2 sanding boards up – years ago – I made them from some scrap pieces of plywood.
       One of them I covered with double sided tape; which the carpet fitters use; and, then, on top of that I stuck a medium grade sandpaper.    I always find this board useful for sanding items flat such as white metal/resin fittings which require a flat surface.
      The other board I made (also years ago) was one which I use for squaring materials up; in other words 2 faces at right angles to each other.   This once again, I made from plywood – it has a vertical piece of plywood glued to the long edge of the base plywood – and this vertical edge is also covered with double sided tape – and then an abrasive paper stuck to it.
      Just wondering if anyone else has made their own tools/jigs which they find exceptionally useful and would like to share their ideas with all of us???
      John W E
        @johnwe
      Home Forums Soapbox Topics
