Help, the engine steam does’t start
Home Forums Steam powered models Help, the engine steam does’t start
  • #57167
    Jose Antonio Alvarez Rocha
      @joseantonioalvarezrocha75530
      First of all, I am completely new in the Alive Steam. I've built a Queen of Africa and I had the idea to use a steam engine. The surprise was that the first time I lit the boiler, the engine ran very well. It only happened the first time. I could never start the engine after this first time. Now, the engine doesn't start. At first the engine is smooth and looks set to start, but when water boils and there is pressure of steam
      the engine becomes stiff and I have difficult to move the steering wheel by hand. Finally the engine doesn't start and I have to abandon everything.
      Please, what am I doing wrong?
      What should I do to fix it?
      I've blown air with compressor airbrush, and the engine starts.
      Thank you
        #57170
          Hello Jose……Welcome to the Forum
          Can you post a picture of the steam engine, please?
          There doesn't seem to be much wrong with it
          Is it new?
          I would recommend that you oil all moving surfaces and run on the compressor for 15 mins
          CAUTION!
          You need to be very careful with steam engines and boilers!
          The boiler needs to be pressure tested, using a water pump, to a pressure, much higher than the normal running pressure
          You need to get a knowledgable competent person to check over the setup and declare it safe, before running again with the boiler, by joining a model boat club and seeking their advice
          All the best……….Bob
          #57175
            There is an item on boiler testing in our Features section under Hints, Tips and Technical:
            There are also several other sample articles by Richard Simpson on steam plants in this section which you may find useful.
            Andy Stoneman
              @andystoneman15177
              Hi, Jose, I think that Bob is on the right track. I am think thinking that as your engine is fairly new it needs to be run in, A bit like a new car, So plenty of oil, Do you have an in line oiler to provide lubricant whilst the engine is running ?Make sure that it is topped up prior to any run on steam. Unfortunately if you run it on Air as Bob suggested it won`t work. So give it a light squirt down the steam pipe prior to running on compressed air, And occasionally during the run in period. If you don`t have an air compressor holding the shaft in an electric drill will also achieve a running in period. If after 15-20 minutes running it still is not looser extend the running in period. Make sure the engine is fully clamped down and mind your fingers.
              Andy
