John,
No worries — if you don't ask, you get no answers!
Every brand of CA glues (at least for modelling purposes) that I know of has several different types in their range; this is true for Zap Glues, for Deluxe Materials, for Bob Smith Industries and others too.
If we stick (pun intende) to Zap Glues, they have ZAP CA (thin, pink label), ZAP-A-GAP (medium, green label) and SLO-ZAP (thick, yellow label): **LINK**. (They also do a gel, a foam safe CA and a rubber toughened, but neither of those should be of great interest to you for this build).
There is also their debonder (**LINK**), but as I said, pure acetone also works fine for the purpose.
One more thing about CA glues. The bottles in which they come have fairly large in-built nozzles, so stright from that nozzle, you are quite likely to get far too much glue on a joint, and it can be rather difficult to control the amount, especially when it comes to the thin variant, which is very liquid!
Zap also sells two different add-on nozzles that I really like, Z-Ends and Flexi-Tips: **LINK**. In particular the Flexi-Tips are extremely useful, and give neigh-on perfect flow control and precision in application. If you don't find the Zap brand flexi-tips, there are similar products available from other brands that should normally fit the Zap bottles as well.
Now, for the Billings instructions, sekundlim and plastlim is not German, but Danish (Billings is a Danish company), and do indeed mean what you think they do. While lim means glue, sekund is second (as in the measurement of time) and plast of course means plastic.
In other words, where the instructions say sekundlim, they mean use a suitable CA glue for this joint, and where it says plastlim, you should use some form or other of styrene plastic glue. I'm sure we all remember the classic Humbrol tubes, although these days my personal preference is for the Tamiya Cement liquid glues that you mention! As usual, there are other brands available, so my recommendations are simply based on what I have tried myself and liked, and I really like the Tamiya stuff.
Actually, the Tamiya Cement also comes in different thicknesses, and should in my experience be used in the same way as CA glues, i.e. the extra thin formula (**LINK**) for capillary glueing and the standard formula (**LINK**) for applying glue before joining the parts together.
In general, anything from Tamiya is usually very good, not least their masking tapes, which are just the right amount of sticky and can be pressed down to give clean and crisp lines but won't lift any previous coats of paint when removed (unless you were careless and didn't give things time to dry, or the paint hadn't at all bonded to the surface which happened once to me when painting a smokestack made from PVC tube).
Mattias
Edited By Banjoman on 29/01/2018 07:02:47
