Thanks guys. I have been in contact with Stuart models and they are sending me a new boiler (they have been excellent with advice and with their service) that has been tested and works correctly. I don’t know whether the fault was with me or the boiler but i have used other model marine steam units in the past without any problems, though this is the first Stuart one.
Gerald – I am using a refillable gas tank (supplied by Stuart models) and the burner is inside the boiler, although it can be removed.
Tom – I have tried lighting it from the top and also by removing the burner, lighting it and putting it back in (the instructions supplied with kit recommend lighting it from the burner first, to set the correct air/gas combination and then light from the top of the boiler – so they differ from the ones in the instructions provided in your link).
I will wait for the new one to turn up and will let you know how i get on….
Cheers guys
Pete
