Hello from Bury Lancashire
Home Forums Beginners Hello from Bury Lancashire
  • #101430
    Mr Johnty
      @mrjohnty
      Hi From Bury in Lancashire.
      Very new to boat building ie never done one before i Had RC cars a few years ago.
      So i went stright in at the deep end and bought my self rather nice Occre Ulises Tug 1:30 only opend the box this weekend.
      Looking forward to starting it not sure if it is a little bit to big a job for my first go time will tell. Im getting a little ahead of my self thinking about colours already lol.
      Does anyone have any opinions good or bad on the Ulises?
      John.
      Mr Johnty
        @mrjohnty
        Hello
        #101437
        Dave Cooper 6
          @davecooper6
          Hi there, and welcome to the forum.
          I'm not a tug man myself but I do know that many people have built them as an introduction to the hobby.
          I assume you're going electric as opposed to IC or steam ? My initial advice would be to read the instructions twice over and try to match the kit contents to the instructions….before starting work.
          No, it's not too early to be thinking about colours especially if you want a scale-looking craft / working boat etc.
          Usually, further questions will fall out as you progress – motors, radio, props, rudders and the various control linkages etc. Just ask away there will be a tug expert somewhere on here to help.
          Happy modelling,
            Hi and welcome to the forum. I don't know what the instructions advise as regards motor/prop/speed controller/battery etc but I would have all those decided before you start building. This will greatly help with component layouts internally as well as initial ballasting tests. For that you should put the completed hull in the bath and then add weights until it is down to the correct waterline. You then take it out, remove the weights and weigh them so you know exactly how much weight you are playing with. The rest of the model will obviously take a good chunk of that and the battery is probably the biggest single item. You might also want to consider some fixed ballast, preferably at either end and leave yourself enough of a safety margin so you can add or remove some removable ballast for trimming.
            Have a look through the links in this thread for potential suppliers:
            Suppliers
            #101444
            Mr Johnty
              @mrjohnty
              hi all.
              Yes ballast the instructions dont say anything about ballast will i need to ballast it ?
              Please help
              John
              #101445
                Almost all boats will require ballast once all the working bits have been fitted.
                There is an American review of this kit which includes a pdf build log but you need to register with their forum to download it:
                There are plenty of online references to the model.
                A low drain 540 type motor with an 8.4v or 9.6v NimH battery will probably be OK such as this one:
