Hi Chris and Ashley,
I just created an account here to be able to reply to you. To sum up at the beginning, I did what you intended to do
many happy faces as a result.
In details:
Platform: Graupner Scimitar Speed
Condition before upgrade: Speed 600 motor applied elsewhere and misplaced during the years. Original spur gear milled to pieces back in the day (propeller got caught in a floating garbage bag at full speed). The original gear ratio was 3:1. Otherwise the boat was in perfect condition.
Plan: The idea was to keep the possibility to run the original motor (actually it is now a Tamiya silver can 540 motor), so I ordered 2:1 gearbox, to increase the speed running on "standard" motor through gearbox. But I also wanted a direct drive option in order to be able to use any kind of motor.
Result: Still having a standard gear option available, but I think I will never use it again (maybe just for training my boy when he gets into RC boats). What I use is Astro Flight 40 Brushless motor running on 12 NiMH through Castle Creations Phoenix HV controller. (And yes, I do not have the reverse option, but so far I had no need to use it.)
The boat is quite heavier in this brushless configuration, but if you look up on the net, you will see that the engine is more than capable of pushing it along (1kW max power). Insane? I know
Balancing the heavy motor so far in front and 12 NiMH batteries was a bit tricky, and I am still not sure if it is good at the moment. I think it would be the best to switch to lighter LiPo batteries. Also, I have not been able to test the max power due to not having the perfectly still stretch of water that is long enough to whip it around at high speed. Due to the powerful motor, the acceleration has to be gradual, as full throttle from standing leads to toppling over (back flip) of the boat.
All in all, it is a lot of fun to drive, incomparable to the standard setup.
In addition, to make the handling and performance more stable and controllable I am now designing the remotely adjustable trim pads. I am not sure if I will be successful but I absolutely have to try that. It would be great to see how to actively balance the weight of the equipment in the boat, and/or to control the ride height of the nose.
As soon as I have some images, if you are interested, I will post them.
Best regards!
Srdjan
