BJ.
Fibreglass for moulding/whatever comes in two main forms. Chopped strand or woven.
The chopped stuff is just that, glass strands chopped up to short lengths and rolled together with a bondinmg agent to make sheets (the bonding agent keeps it together and melts with the resin). OR
Woven, which is just like cloth, and comes in various thicknesses from stuff like silk stockings up to sacking. The very fine stuff conforms to curves like Mae west`s bodice (sorry I used that elsewhere) and is useful as it really does drape round even tight curves.
J-Cloths. Yes, the cleaning cloths. They are very tough and yes they will not be as smooth after application, but you are not building a racing boat. After three applications of resin I should think they would be smooth enough. Trevor here at the pond used J-cloths to make a tube for a motor housing and we were well impressed, and I will be using it for internal reinforcing when the time comes for such things.
ALTERNATIVLY, probably simply painting the surfaces with PVA glue, say three coats would provide you with sufficient protection…no cloth or anything else…actually, using J-cloths and PVA would be a really good cheap covering, not hard like resin, but bump-proof. It would not crack like thin glass coverings either, a point to consider.
Gorilla glue, the foaming stuff works really well and is economic for use on large surfaces. Epoxy is great but you would need quite a bit and then it becomes expensive. You do have to make sire the foam cannot move when using Gorilla glue as it does push the bits apart when foaming up.
