Fittings For 1/12 RNLI Arun
Home Forums Building Kits Fittings For 1/12 RNLI Arun
  • #92415
    Mark Nugent
      @marknugent25605
      I am looking at purchasing the hull, deck, wheelhouse and plans for the RNLI Arun rescue bost from Mount Fleet Models. How difficult will it be for me to get the 1/12 fittings? I have 3 3d prints so I know I can print some but would rather go with metal.
      I am also looking at the 72-inch version of the RNLI Clyde. Not sure what this scale will be? Any help figuring out the scale based on the length?
      Thank you all
      Mark Nugent
        @marknugent25605
        Scale Fittings
        #92417
        Mark Nugent
          @marknugent25605
          the measurements for the life size Clyde is 71 feet by 18 feet. Anyone want to try and figure out the length, width and scale using these numbers? I am not good with these type of figures.
          #92419
            Macs Mouldings do a number of RNLI 1:12 scale fittings but they are in resin. Still good though.
            The Clyde might be rather more difficult…
              That's an easy one Mark. Call the full-size one 72 feet and that gives a scale of 1:12 and therefore the width is 18 inches.
              That will be a big heavy model!
              Mark Nugent
                @marknugent25605
                That will be a big sucker. I have found an amazing site for 1/12 fittings. They actually have a special section for RNLI large scale models. Macsmouldings. I will have to build some type of transportation cart from my truck to the water.
                #92422
                Mark Nugent
                  @marknugent25605
                  Thanks Colin and Chris. What are you building?
                  #92423
                    Mark,
                    Martin at Macs Moudings is very helpful and his fittings are excellent quality.
                    What am I building? At the moment SS Miltiades a 1903 liner on the UK Australia trade as built with a sigle funnel. Model will be 1:150 scale.
                    Edited By Colin Bishop on 22/11/2020 19:54:27
                    #92424
                    Mark Nugent
                      @marknugent25605
                      Wow. That looks like a difficult model. Are you scratch building it? How long will a model like this take you from start to finish?
                      #92425
                        Yes, scratch building using a 1:1200 waterline plan, photos of the builder's model that used to be on display in the London Science Museum plus photos I took of the builder's plans at the National Maritime Museum archives at Woolwich.
                        It's all a bit of a jigsaw but I'm getting there slowly. It will take as long as it takes!
                        It will be a unique model anyway.
                          MARK, i made the actual moulds for the Clyde class lifeboat some years ago and they are accurate for one of the 3 boats only…….70-002 Grace Paterson Ritchie. the other two boats 70-001 Charles H Barrett and 70 – 003 City of Bristol were both slightly different to GPR and to each other………..but the hull cabin, flying bridge, fore companion way were grp mouldings.
                          However, i gave them to metcalf mouldings, who passed them on to Models by Design, who eventually sold them to Mountfleet Models.
                          i did make a full set of rubber moulds for moulding resin fittings and for personal reasons sold all of those moulds for fittings to Adrian Gosling at Speedline models for 2 pints of diet coke..
                          i would suggest you contact Adrian and ask him if he still has those fittings moulds and if so, run a set off for you.
                          hope this helps you.but beware.they need an incedible amount of ballast, and very large motors to power them,
