Hi Looverlijn,
whilst on this topic, and without hijacking it, can I ask what must seem a "stupid question" of you all. I've just fitted twin shafts to a boat conversion, and added 4 blade props, LH and RH . The shafts come threaded at both ends with the inner end having a nut and two washers, the outer a nut and single washer. The washer is to the tube at each. The shaft has a note to "grease the shaft before running".
The question is, are these nuts at each end to keep the shaft in its tube, as they tighten up to give just a slight movement longwise in the tube without catching. If they are for that, as thats how they appear, then do I require to add another nut to act as lock nut for the propeller (or as I normally do, rely on thread lock.)? Threads are M4 so no problem to find one.
I made a Gareth designed prop tool way back when he first mentioned it – very handy too. And I note my trusty Thames barge has a large prop with nut facings already on its rim, so two spanners lock it on using a lock-nut, without touching the blades at all.
Kim
