First timer
First timer
Home Forums Building Kits First timer
  • #14891
    Richie
      @richie
      I am about to start building the "Anne Letitia Russel", Watson class Lifeboat as my first real model.
      If anyone has built this model, can they pass any hints or tips they found during build or what motors / batteries they have used etc
      Cheers
      Richie
        hi Richie, I know the kit of the ALR intimately as well as the plans and the instructions.
        My best advice to you is to follow those instructions word for word and step by step and you shouldn’t have any difficulties.
        They were written by a modeller for modellers who was fed up with building kits with great wodges of areas missing that needed explaining, and as such wrote the instructions as he designed and built the prototype.
        They might be a little long winded at times but they try to explain any of the pit falls for a novice builder, at every stage.
        As for motors you will not go far wrong with something similar to 555’s operating on twin speed controllers as she has a great manouverability with individual controls and that size motor will give a good scale speed….remember the real boats would only do 7 – 9 knotts with a wind behind them!
        Give it a go and try it..
        #14893
        Richie
          @richie
          Hi Neil,
          Thanks very much for the information. I also feel privileged as I believe you made the original design for this kit.
          I will not quite be laying down the keel tomorrow but will start with fabricating a stand for the hull. Hopefully I will make a reasonable job of the model, although I am wary about the painting. All of these boats were immaculate when at the stations and as an ex-crew and enthusiast I have a particular soft spot for Watson class boats.
          Richie
          #14894
            cheers, Richie. if you need any help, just give me a shout.neil.
            #5934
            Richie
              @richie
