G'day Paul,
It is not evident in the photos, but both the torch burner with the sought flame and the other, are operating direct from the disposable gas can shown in the other photo. I normally use that system to recharge my copper gas tank, but I wanted to demonstrate with the direct pressure from the source.
The boiler was constructed using a suitable length of 1.5guage copper pipe and same guage ends. The ends being further reinforced by 2 6mm s/steel rods running through the boiler and the rods also serve as mounting points for the completed boiler. All boiler joints and bronze bushes being silver soldered.
I always soft solder the supply pipes so that should the boiler run dry or the safety valve malfunction, then the system will fail at the weakest point and not explode. That is the theory at any rate. It has actually been tested once when I accidently let the boiler run dry and the heat then melted the soft solder and released the pressure with only damage to the stem pipe line. Similar to the sacrificial wire in you car electrical system which will burn out before your entire electrical system is destroyed.
As you can see, Martin has recommended I seek info. from july 2008 issue so I will continue to make more burners and who knows, I may yet stumble over the correct unit. I cannot recall the Latin phrase, but in English "bash on".
I have struck a number of problems during the construction of this steam engine system. Probably all due to inexperience, but using trial and error I have reached this stage and I refuse to be beaten by the final problem. There is an answer somewhere.
Thank you very much for your assistance and advice
Kind Regards
Eric
