Fibre glass hull and nothing else what to do?
Home Forums Beginners Fibre glass hull and nothing else what to do?
  • #82273
    Richard Caughey 1
      @richardcaughey1
      Whilst at the club yesterday I spotted a fibreglass hull on the bench that was foc to anyone that wanted to build a boat with it. So I couldn’t resist and now it is at home with me firstly wondering why did I do it and secondly thinking now how or what do I do with it……. I am ok sawing/ cutting a bit of balsa and fibreglassing a deck in place, I have skills with Diy tools etc, BUT, what motor/prop shaft/prop/ electrics should I put on it and anything I need to watch out for, heat? Where in the boat should the motor fit? Middle towards the back? Aft?
      I have built several electric planes up to 6s so some knowledge of motors lipos esc etc.but what sizes do I need for a 90 cm fibreglass hull? I am not looking to break the land speed record just don’t want to be embarrassed by a boat that looks like a speed boat moving like a canal barge, so something in between would be good.
      i was thinking I could just pull a motor esc combo out of one of my planes and just put it in the boat, with a prop and propshaft combo from prestwich models, would that work?
      I will go and talk to the guys but find I get good advice here so I thought I would try you guys first.
      Richard Caughey 1
        @richardcaughey1
        How to build it
        #82274
          Hi Richard
          Post a few photos and let us know the hulls length, breadth and width.
          Richard Caughey 1
            @richardcaughey1
            No laughing at the motor !
            Length 90 cm, width 30, hull depth 8 cm, I posted a pic with a motor I took out of a plane, coke can just for sale.
            #82276
              HI Richard
              A 35mm brushless 1100 to 1450kv with power about 800 to1600 Watts, 100A ESC, 3 or 4S Lipo around the 5800mah and prop 2 blade 40-45mm.
              Harry Smith
              #82277
                Hi Richard
                Can't make out many details from the single photo, it would help to see views from all sides.
                Richard Caughey 1
                  @richardcaughey1
                  More pics added
                  #82279
                    Hi Richard
                    It looks like a very fast hull and could be made into a screaming demon.
                    Richard Caughey 1
                      @richardcaughey1
                      Maybe by someone that’s know what they are doing….. and I am fast discovering it won’t be cheap to do either!
                      It might go fast but with what motor, I was thinking hobby king aquastar 3974 2200kv with a 150A esc a and starting with3s and the increasing to 6s? Depending on what happens.
                      I really don’t know what I am doing on electric boats motors rudders propshafts etc. So if it is really fast it will be more by luck than skill. The rudder and propshaft is one off eBay 392116782851 flexishaft and rudder don’t know if all that will do it?
                      I think I need to do more research? How long a propshaft how long should it stick out of the back? What prop ?where to mount the motor…
                      I am happy to take cheaper alternative suggestions just to get the boat going
                      I do ok with yachts now but fast electric is completely new to me.
                      #82282
                        Hi Richard
                        Getting down to brass tacks !!!
                        Hobbyking 3648-1450kv (1600 Watts) (T3648-1450), car ESC 100Amps 2-4S( HK-100A), ESC program card (HK PROG-CARD),Lipo 3S Turnigy 5800mah 3S 25C or 4S Zippy Compact 5800mah 4S 40C.
                        ESC set up
                        1 Cutoff Voltage for 3S=10.2 and 4S=13.6
                        2 Start Power Percent=5%
                        3 Advance Timing=4
                        4 Run Mode=2
                        5 Brake Force=1
                        6 Drag Brake Force=1
                        7 Neutral Range=1
                        8 Initial Brake Force=1
                        9 Reverse Force=1
                        Prop shaft 4mm solid shaft with a 2 blade 40mm for 3S or 4S batteries.
                        We have used this setup in a number of boats around that size (Huntsman, Swordsman, Spearfish and Sea Commander).
                        Harry Smith
                        #82285
                          1600 watts!!! My my Harry my lad. I know you have a large lake to sail in…I only hope Richard has!
                          Richard Caughey 1
                            @richardcaughey1
                            A month on I put an aqua star motor 2200 Kv 2 – 4 S battery not yet decided on battery and build still in progress.
                            I need help on finishing the deck need to go on the build section for that? It’s currently very thin basswood, the help I need is how to finish it? Do I just prime and paint or will it be better to mix some fibreglass resin and paint it withe the resin or use fibreglass matting and resin?
