Hi John
Motors are Graupner 600 ECO, with 30mm 3 blade brass props.
I'm driving at 12v (2 x 6v 12Ah AGM) and nowhere near max power as the scale speed would be stupid fast.
Yup – I'm expecting to have to buy a second ESC but…
As well as current limiting, my ESC has thermal limiting too (they're more usually used for robotics applications).
The batteries i'm fitting arrived today so I should be able to get the hull in the bath.
Static water is worst case. If it works in static water, it'll be fine on the pond.
If it goes into current limit, or thermal limit, i'll have my answer.
