Fairey Huntsman 28
Fairey Huntsman 28
Home Forums Build Blogs Fairey Huntsman 28
  • This topic has 196 replies, 2 voices, and was last updated 1 month ago by Colin Bishop.
Viewing 22 posts - 176 through 197 (of 197 total)
  • #88617
      I think the boat I had in mind was smaller than Spearfish and had only one jet. I shall consult my oracle Scott and see what he can dig up.
      I recall a story he told me about legendary boat designer Sonny Levi, who was once asked why a jet conversion of an Aquarama was so slow and wallowing compared with the prop-driven version, Apparently Sonny took a long drag of his habitually-present ciggy and said "Well – there's the half-ton of water sitting in the jet inlet for a start – you might want to work on that"…
        @timrowe83142
        Even worse is that 1/2 ton of water has to be lifted from the inlets on the hull bottom to where the jets exit on the transom. That is another effective increase in displacement and what's worse, the displacement increases as the boat goes faster.
        Great system for jetskis and boats that can't have anything sticking out the bottom but very hard on impellers, expensive to maintain. A lot of super-fast ferries use jets.
        Tim R
        #88624
          According to the book the confusingly named Swordsman 30 was built in 2004 and all were fitted with a single diesel and waterjet even though other options were available. This used the Spearfish hull.
          Edited By Chris Fellows on 02/06/2020 15:18:09
          #88625
            Posted by Chris Fellows on 02/06/2020 15:16:16:
            That's the one. I'm glad I didn't imagine the whole thing! Swordsman 30
            Edited By Dave Milbourn on 02/06/2020 15:39:01
            #88642
              Hi Chris
              I near missed that little dig !!!!
              But in scale up speed I think my mates Spearfish on or over the 55 Knots.
              It's only on 4S and the motor (3648-1450kv) is rated to 6S !!!!
              On 4S 5800mah Lipo
              Prop 2 blade 38mm 1.4 pitch draws 60Amps speed 36kph.
              Prop 2 blade 40mm 1.4 pitch 55Amps 37kph.
              Prop 3 blade 37mm 1.4 pitch 60Amps 37kph.
              Have you decided to sell me the Spearfish kit or you going to build it ???
              #88662
                Hi Harry
                Dig, me!!! smiley
                I doubt that I will build it as I'm building the Huntsman 31 Sport. It's getting it to you which is the problem! Certainly at the moment. You can have it for what I paid for it. We can look at posting options once some sense of normality has resumed and see if it is viable for you.
                Edited By Chris Fellows on 03/06/2020 16:36:15
                #88684
                  Hi Chris
                  I was told that Interparcel is good( by DM).
                  Also Parcel Post.
                  Is it the Mark 1 or 2 ??
                  The Mark 1 had a lift out floor.
                  The Mark 2 the cabin lifted off.
                  #88853
                    Hi Chris
                    Can you PM me please ???
                    #88878
                      Hi Harry
                      As you can see from the box you're out of luck, no mention of TAS or even AU! Only GB, D and F. That's a pity! smiley
                      Is it the Mk. 2 that you prefer?
                      I've set up an album with more piccies.
                      Edited By Chris Fellows on 09/06/2020 16:32:34
                      #88897
                        Hi Chris
                        Can you find a company that post to Australia, please ????
                        That's one beautiful kit, mate.
                        #88898
                          I've just entered a guesstimated set of measurements for that kit to Australia through Interparcel and you're talking around £120 plus insurance c/o Fedex Priority. The next cheapest was £160. The carriers who quoted are Fedex, UPS, Parcel Force and TNT.
                            I'd done the same Dave and PM'd Harry to see if he wants to proceed.
                              Posted by harry smith 1 on 10/06/2020 10:03:52:
                              Hi Chris
                              Yes, not bad is it. From the photos you can probably see there are some yellowish patches on the deck that are under the blue but they are in the area that is to be cut out. Also there is a very minor scradge on the bottom of the hull in the middle. Other than that it is mint.
                                Hi Chris
                                Looks like I will have to pass on the boat because of postage cost.
                                As for the kit and age it's the best one I have seen.
                                I enlarge all Chris's pics and it's a dam good find !!!
                                The Fairy Godfather is not smiling down on me, but I will keep looking.
                                May have to dig out the Sea Raven and get that finished !!!
                                Cheers and Beers
                                #88915
                                  Ok Harry, I'm not surprised, we thought the postage would be a killer. sad
                                  Once I've built all the other Faireys that I want to I'll maybe build it in the future.
                                    Hi Chris,
                                    So by the way you are decorating your place, we are talking 2030 ?? 😄😄😄
                                      Thanks Ray! cheeky
                                        Can't believe the last post date! But as I keep saying I will have five boats ready pretty much at the same time!
                                        As mentioned on another blog I'm painting this hull as well. The whole hull was coated in white primer undercoat to highlight any areas that needed filling. As expected, there wasn't much and minor imperfections were duly filled and once dried and sanded the areas were spot primed and then sanded.
                                        With this hull the sides and transom are going to be white and the bottom blue and this morning I applied the first coat of white gloss. I shall continue applying coats of white until that is finished and then start on the blue.
                                        #125924
                                          Dusted this one off! Been painting the inside of Faun and whilst in painting mode thought I’d have a look at my previous builds.
                                          Like the Huntress LC and River Cruiser I want to take this one (and the Swordsman) for lake trials so I’ve put the first coat of undercoat on the bottom of the hull in readiness for the blue.
                                          I’m using good quality 3M tape to mask off between the two colours but I’ve got a question for my fellow hand painters. can I leave the masking tape on until I’ve completed the undercoat and gloss layers (maybe 3 gloss) or do I need to remask after each coat and remove whilst the paint is still wet? Obviously I’d rather not have to remask each time but don’t want to damage the paint edge.
                                          Painting 1
                                          #126011
                                            4 or 5 coats (I’ve lost count!) of gloss blue applied to the hull bottom and the masking tape removed whilst still wet. Paint lines were pretty good in the main, apart from some bleeding at the junction of the strakes and chines due to difficulty with getting the making nice and tight. With hindsight I should have left a small gap between them. I have the same problem with the Swordsman but at least the strakes are bigger and I shall be more careful. Managed to get it off OK carefully using a craft knife.
                                            I really have a love/hate relationship with painting. I love that I’m getting some paint on but get frustrated (particularly with hand painting) because of the dust etc. that settles on it and spoils the finish, especially with darker colours. Grrr! Other aspects of building are under control but not so painting. Use good quality paint and brushes but you are then at the whim of outside influences unless you’ve got a proper booth with extraction. I know some folks use the bathroom!
                                            Anyway I want to get it on the water so I’m leaving it there – and also get on with the others. Maybe try cutting it back and polishing it later once the paint has hardened off?
                                            I’ve got a cardboard box to fit over the smaller models but not this one. Will have to sort something out for the bigger ones.
                                            Painting 5
                                            Painting 6
                                            #126071
                                              Lake trials today! Centre of Gravity is maybe a little far forward of the ideal but Fairey models in my experience are pretty tolerant (Huntsman 31 may be the exception?) but she sits on the waterline fine, comes up onto the plane easily and turns well. So, pretty happy with that.
                                              Installation 1
                                              Lake Trials 1
                                              Lake Trials 2
                                              Lake Trials 3
                                              #126072
                                                Looks fine Chris.
