Hi Bob,
There are four foot hulls and four foot hulls. A 4'x10'' tanker will weigh more than a 4'x10'' steam yacht as they have different block coefficients, ie the tanker will represent much more of the rectangular block measuring 4' x 10'' than the steam yacht, the latter being much finer lined.
I don't think your Silver Mist will be anyting like 40 or 50lb. I shouldn't get too hung up on the final weight. I just wanted you to know that it will be quite heavy and will require a fair amount of ballast. The Silver Mist hull isn't as burdensome the same sized tug might be, which could well weigh 40lb. There's no real way round it- it must float to its designed waterline or, as you say, it will look silly. Removeable ballast or water ballast tanks may be a way to go- but it won't be that heavy. The other alternative is to go back to 42''- still a good size.
The nice thing about heavy models as you know, is the way they sit on and move through the water. I think your Silver Mist at 48'' will be brilliant and I can't wait to see how you get on with it.
Have fun and all the best,
Edited By Ian Gardner on 01/04/2016 13:51:42
