Bob, that’s a good scheme, providing two different visual indications and an identical setup each end.
Since the galvanometer is connected in series across the bulb, it measures the voltage rather than the current. Still, a reasonably sensitive galvanometer will take a negligible current, so the main factor remains the current drawn by the bulb.
A 10W 12V bulb is similar to a car side-light, it will be visible for many hundreds of yards. Perhaps it would be overkill? The bulb I’m sending Bob is 1.2W (0.1 Amps) and is perfectly visible at a sensible close range.
By the way, the 1 Amp limit is my personal estimate for wire of this sort, and may be a little conservative. Neither the Maplin nor RS version have a specified current limit as these cables are usually used for audio signals not power. Still, I’m sure it will be quite suitable for the job.
Just let the Beeb techies know that we recommend a 1 Amp current limit and I’m sure they’ll be able to keep to that for the kit used for filming.
