ESC Beep Beep Beep constantly
Home Forums Beginners ESC Beep Beep Beep constantly
  • #2890
    Andy hop
      @andyhop65854
      marine 90a 900kv b/m
      Andy hop
        @andyhop65854
        Hi
        I received the new brushless motor 900kv like suggested and and a 90A Marine Turnigy ESC + programming card
        I have connected up all wires went though programming steps with programming card & transmitter and all I keep getting is this ruddy thing keeps beeping at me ihave tried reversing wire still same cant seam to get it in programming mode any info you good fellows ?
        #85011
        Andy hop
          @andyhop65854
          sorry its the motor that's beeping ]
          #85012
          Andy hop
            @andyhop65854
            Thinks ive sorted it its this sh@t radiolink AT9S TX
            #85013
              Annoying things these: Everything has to be checked if you have an issue….battery fitness (charge/voltage), stick position (up/down/centre/normal/reverse), polarity of rx lead.
              Program card essential, and you have one which is good.
              The motor is the thing that beeps, the esc buzzes the motor as far as I know…the esc`s do not have a speaker/whatever…?
              Dave Cooper 6
                @davecooper6
                Hi Andy,
                I use substitution to solve these 'mystery' faults :-
                ESC with different motor
                Different ESC with planned motor
                By-pass 'jumper' leads instead of the usual connectors (be careful not to 'short' anything !)
                etc. etc.
                Motor 'beeping' is usually a sign that the ESC is confirming a programming command. Different beep patterns confirm specific commands eg Soft Start, Motor Braking etc.
                Best consult your ESC /Card instructions to see if a regularly occurring beep is, in fact, a valid command.
                Failing this, consult the manufacturer's website "FAQ" section….it's likely that others have also seen this condition too.
                Good hunting,
                  In the old days you could just switch the thing on.
                  Progress?
                  Andy hop
                    @andyhop65854
                    Evening
                    Iv'e sorted it , was sumate in the radio after a few headaches
                    I reset the AT9S to factory and updated the firmware
                    Hey presto all ok now ff
                    Thanks very much for your input ..
                    #85056
                    Andy hop
                      @andyhop65854
                      Evening
