I seemed to have missed the excitement when this thread was current!
For what it’s worth, iron losses and temperature rises do have real effects on motor performance. But the calculations I’ve put out there have used the 80:20 rule, to get 80% of the way to a useful answer by applying 20% of the calculations.
60 Watt: My calcs were based on first principles, including T=KtI, E=KvN, Kt = (Kv in v/rad/sec) and Ohm’s Law. They match manufacturer’s published curves almost exactly. If you’re interested, PM me an email address and I’ll gladly send you my spreadsheet.
Barzo: IMO I think you’re cooking your motor and would do well to run water cooling 100% of the time.
Here are some suggested golden rules for motor-prop sizing, for those without a laser tachometer!:
1 – Use the recommended motor for the model you’re building, or if it’s a scratch-build then pick a similar hull which performs well and use a similar motor.
2 – Run the motor at, or below, the rated voltage, but NEVER above it, unless you’re racing and know what you’re doing.
3 – Run your motor at full throttle with the boat out ot the water, (no-load) and listen to the pitch of the motor sound. Now run the boat full throttle on the pond. If the motor pitch on the water is more than one octave below the no-load pitch then you’re running on the EVIL side of the torque curve, your motor is over-loaded, is overheating unnecessarilly and delivering less shaft power than it could. In this case, choose a smaller prop or one with a finer pitch. That smaller prop WILL make your model go faster, cook your motor less and make your battery last longer!
4 – For a non-planing scale hull, the best compromise between efficiency and performance is when the shaft is loaded so that on the water it’s running at 75% of the no-load speed, or three full-tones below in pitch. (If no-load the pitch is uper C with the throttle wide open, then on the pond the tone should be G below). If not, adjust the prop size or pitch to suit. This will give you around 90% of the maximum motor efficiency and the best battery life. If the performance is inadequate, change to a larger motor and repeat.
5 – For a high-performance planing hull, you need to accept short battery life and a cooking motor. Choose the best water cooling arrangement you can, as hot motors not only have short lives, but deliver less power. Select the prop to give a water pitch just less than an octave below the no-load pitch. (If no-load the pitch is uper C with the throttle wide open, then on the pond the tone should be middle D). If the performance is inadequate, change to a bigger motor as you have already got the most from the one you have.
I’d be delighted to hear how these rules apply to real models in practice. If your scale model runs with a motor pitch more than three tones below the no-load pitch, does your motor get hot?
