December 2013 Model Boats Magazine
Home Forums Soapbox December 2013 Model Boats Magazine
Viewing 24 posts - 1 through 24 (of 24 total)
  • #45086
    Mike Pendlebury
      @mikependlebury45959
      As a subscriber I have just received my copy of the latest Model Boats Magazine and the free plan is incomplete. It's only printed on one side! Is this just my copy or is it a problem with all the copies??
      Mike Pendlebury
      Mike Pendlebury
        #45087
          Mine is the same. Looks like an error as it says two sheets on the header. I have reported it to Paul Freshney.
            I have thoroughly enjoyed reading my copy today and whilst the second sheet of the free drawing is missing its the only mishap that I have ever encountered in all my years of reading the magazine.
            Is it really worth worrying about?
            Edited By Paul T on 16/11/2013 17:57:03
            #45090
              Well, it might be if you were thinking of building the model Paul but no doubt MTM will make it available on request if that is the case.
                I do appreciate that someone might want to build the model and I am sure that MTM would sort out the problem and I don't wish to appear blasé about the matter but in the great scheme of things a few missing drawings isn't all that important.
                Gary Goldring
                  @garygoldring70604
                  Thank goodness, I thought it was me!
                  Definitely short of a sheet; otherwise the magazine is as execellent as ever!
                  #45093
                  Mike Pendlebury
                    Posted by Paul T on 16/11/2013 18:32:38:
                    It is a problem, and it is important, if you want to build the boat and the hull lines sheet is missing.
                    Mike
                    #45094
                      Well it's not important in the universal scheme of things Paul but I suspect a few questions will be asked on Monday. When publishing a national/international magazine we do try to get things right as the customers would expect. Obviously mistakes may happen from time to time but the reason needs to be determined to stop them happening in future.
                      Gary Goldring
                        @garygoldring70604
                        I know this is only my second ever post but I have to agree with Mike and Colin.
                        I am thinking about getting back into boat modelling after too many years, hence my new subscription to MB. Aquarius looks like an interesting project to start again with – but not without the lines plan!
                        I'm sure it will be sorted, hence my decision to check the forum to see what is happening.
                        By the way, thanks to you all for providing a lot of good background info in earlier posts – very useful.
                        Gary
                        #45100
                        The Long Build
                          @thelongbuild
                          Not sure in what way the mags are sent (geographically, alphabetically )out but could be helpful in the investigation.
                          And yes I have a blank 2nd page unless it is actually there but it is a test to see who can make the invisible ink show its self..
                          #45101
                            I am told it is a printer's error and that further information will be posted here on Monday. It is likely that readers will be able to apply for the full plan to be sent to them if they wish but this is still to be confirmed.
                            Paul Freshney
                              @paulfreshney24971
                              Colin and I have spoken earlier tonight.
                              It is clearly a printer error and not MyTimeMedia as the two sheets are shown within the Printer's proofing system and the print order (generated by H/O) clearly also requires the two sheets to be printed back to back.
                              So someone at the printers has 'mucked-up' or there has been a mechanical error, but more likely 'human'.
                              After approving the proofs, I don't see the magazine until it arrives on my doormat.
                              I have alerted H/O who no doubt will resolve on Monday and as Colin has said, their solution will be on here asap.
                              So, sorry for for the inconvenience, but no doubt the Printer will get the bill for sorting it all out.
                              Paul Freshney
                              Editor
                              #45103
                              The Long Build
                                @thelongbuild
                                It Happens.. Had a Breakaway once , All chocolate with no biscuit in it, Wondered if I should send report it to the hotline after eating 2/3rds of it…cool..
                                Would imagine it was hard to see once the production line was going as I assume it is all assembled by robots, when you look at the plan when stapled in you do not readily see the blank parts of the plan..
                                #45121
                                Paul Freshney
                                  @paulfreshney24971
                                  To all UK subscribers
                                  Every care is taken to provide a full and comprehensive edition every month for your enjoyment and on the rare occasion where you may experience problems, we will always try and find a solution as quickly as possible. In this instance, the missing sheet of the RAFA Aquarius Free plan is entirely the fault of the printers and was beyond our control. Fortunately, as regard export and newstrade copies, these issues have been withdrawn from the distribution system today to have the complete two sheet plan added to them and they will then be re-dispatched as usual.
                                  In the case only of UK subscriber copies which were posted-out at the end of last week, any UK subscriber who wants the missing plan sheet should contact Audrey at: [email protected] or telephone 0844 543 8200, clearly mentioning MB Dec 2013 and the missing plan sheet, giving their name and full address and it will be posted out free of charge asap.
                                  I understand and regret the inconvenience this may cause, but the error was not of our doing. The solution is the most practical in the circumstances for UK subscribers, with the printers bearing all the associated costs. A note about this will also appear in the January issue which follows quite shortly in early December.
                                  Thank you for your understanding.
                                  Paul Freshney
                                  Editor
                                  Monday 18th November
                                  #45124
                                  Frode Marton Meling
                                    @frodemartonmeling29281
                                    Its not only UK. I received my magazine in Norway on Saturday and the second page is missing.
                                    #45126
                                    Paul Freshney
                                      @paulfreshney24971
                                      Hi Frode
                                      Perhaps it should have said 'UK based subscribers' as distinct from North America.
                                      Assuming your subscription is via [email protected], then just email them as per that posting please with your details, if you want the second sheet.
                                      Paul Freshney
                                      Editor
                                      #45181
                                      Paul Freshney
                                        @paulfreshney24971
                                        Thursday 21st.
                                        It would now seem that all subscription copies processed by CDS, and that includes those that go to Europe and the Far East (Australia & New Zealand) were dispatched last Friday 15th. We were given to understand that only the UK ones were dispatched from them on that day.
                                        Hence, any subscriber anywhere, wanting the missing sheet, apart those in North America who deal with Express Magazines, should contact Audrey at [email protected], or tel: 0844 543 8200, clearly mentioning MB Dec 2013 and the missing plan sheet, giving their name and full address, and it will be posted out free of charge asap.
                                        ​I suppose on the plus side, that this does go to show that the subscription copies really are normally dispatched a week before the 'on sale' date.
                                        All the newstrade and North America copies should have the two sheets.
                                        Paul Freshney
                                        #45264
                                        Mike Pendlebury
                                          The missing plan arrived today and my son is now happy as he can get on and build the boat!!
                                          Mike
                                          #45265
                                          Frode Marton Meling
                                            I got mine in Norway also today
                                            #45269
                                            Paul Freshney
                                              @paulfreshney24971
                                              Thanks for posting today, as it shows the arrangements are working.
                                              Good luck with your models.
                                              Paul Freshney
                                              Editor.
                                              #45275
                                              LARRY WHETTON
                                                @larrywhetton68737
                                                purchased my MB with plan in a nice plastic cover , from local W.H.S. …….
                                                Nice plan and contents …….cheers Larry…
                                                #45295
                                                The Long Build
                                                  @thelongbuild
                                                  Replacement Received smiley
                                                  #45296
                                                  mike farrell
                                                    @mikefarrell21522
                                                    Friday at 6.00 received my copy from Longmoors newsagency complete with plan .Great service and like the content.winkMichael.
                                                    Remember amatuers built the Ark and professionals built the Titanic
                                                  Home Forums Soapbox Topics
