Ian,
I did the review, it appeared in the 2012 Winter Special issue. I enjoyed the build although it did benefit from a bit of tweaking here and there. I also got the GRP superstructure casing in place of the standard vac formed unit that is provided with the kit. It is one of the older Deans kits and contains a greater proportion of wood than the more recent ones which use plastic decks. The boat performs very well with a 30mm 3 bladed brass prop. I originally fitted a 25mm one which was adequate but which left nothing in reserve.
I don't think there are any official back issues on sale at the moment but you should be able to pick one up on the Net or maybe someone on here has a spare one. If not let me know and I will send you a scan of the article.
