Cheaper power pack/vac
Home Forums Soapbox Cheaper power pack/vac
  • #93151
      These handy vacuum cleaners are great are great around the workshop in these dust aware days, and I may buy 3 more to strip down for the motor, battery & charger great for an economical way of powering that next boat or 3 £14.99 from 17th January.
      Regards Ray (cheap dept)
      Picture to follow
        Lidl rechargable vacum cleaner
        #93152
          #93155
            Hmm…might be able to use motor, impeller (and batt) for something water-jet powered???
            Chris E
              @chrise
              I am not sure why this is such a good deal.
              The charger will have a dedicated socket for the vacuum & is probably sealed. Most of us own a charger anyway.
              The motor is unknown spec . Who knows what rpm it achieves nor what size it is but if the spec is right it runs around 5A – 6.5A in the vacuum .
              So for me £14.99 buys a 2200mah 7.2v battery and a difficult to use charger.
              Am I missing something?
              Edited By Chris E on 10/01/2021 14:12:42
              #93160
                Hi Ashley,
                Yes I can see your planning Thunderbird 4 with the wet vac option
                Chris, I cant remember ever buying a battery for a boat in the last 10 years for as little as £14.99 and it has a motor which will run for 22 minutes, what's not to like ??
                Chris E
                  @chrise
                  Ray
                  It so much depends on what you want to use them for.
                  I am guessing that they are a couple of this series of batteries at £4.09 each so 7.4v 2500mah for £8.18. rated for 8C (20A)
                  18650 cells
                  I have one of these & the batteries are fine for low current use & they are a great torch! 2 x 18650. I suspect that the 6400mah is fictional and I have no idea on the discharge rating but it sure does work. I give this as an example rather than a specific recommendation. There are lots of similar worklights around. They are also very good for lighting the bits that are always in shadow although for modelling you will only want half power or strong sunglasses.
                  Amazon Work Light
                  #93168
                    Well I will let you know what they are like on Sunday 17th
                    The proof of the pudding's in the box I guess. I'm not sure where the 6400mah or the torch came from ?
                    Chris E
                      @chrise
                      Ray
                      Any good?
                        Hi Chris,
                        Yes I bought a couple for a rainy day and one for my old mum 88 she loves it they are a nice product and very handy around the workshop, If I get desperate for a motor & battery I will strip one down.
                      Home Forums Soapbox Topics
