Also i would
prefer direct drive running on 12 volts. I have used 7 and 12 pole
motors in the past which seem to have plenty of torque but i have not
seen any advertised recently. Any advice would be greatly appreciated.
When that item expires look for an item in his
Ebay shop
A walloping great 1000mNm of stall torque on 12v
Motor spec:-
Body: 52mm dia 85mm long
Shaft: single end 5.0mm dia ballraced
Commutator: 12 pole, low noise
Voltage: 12v DC
No load RPM: 6700 1.2A
Max efficiency: 5250rpm, 1500g cm, 80w, 12A, efficiency 55%
Max power: 3200rpm, 3500g cm, 115w, 24A
