Unless you have the kit the plan will only be of very limited use as parts of it are likely to be not to scale not to scale and there is no information which would enable you to build the hull (lines plan etc.).
When these kits were originally designed, the manufacturers only provided enough information to build the kit in order to prevent the design being copied and sold elsewhere
I have removed your email address as it is not a good idea to list it on open forum. If anyone an help they can send you a private message.
Edited By Colin Bishop on 09/08/2018 10:03:20
