Building a model from scratch
Home Forums Beginners Building a model from scratch
  • #93575
    Jeremy Barker
      @jeremybarker49985
      Hi to all, I'm new to the group
      So time to get down to my problem, I'm building a model sail boat out of scrap 1×12. I've got the hull cut about 80% I still need the roll and shape the hull. Was looking for ideas on how to rile the hull. Here are a few pics and I still got to take out some wood out of the cockpit. Ullpist some pics when I figure out how to do it..
      Jeremy Barker
        @jeremybarker49985
        #93578
          Is it being carved from solid?
          Is it intended to be a working model (i.e. actually sailing) or a static display piece? Different considerations apply.
          #93581
            A guide to posting images here:
            Dave Cooper 6
              @davecooper6
              Hi Jeremy
              Welcome to the forum.
              From your 4 photos, looks like you are carving from solid ? Pine perhaps ?
              As Malcolm says, we really need more info' from you – eg what does the " 1 x 12 " refer to…
              For a display model, carving from solid should be fine. If you are not working from drawings /photographs of a full-size boat, I would go with what 'looks right'.
              For a model to actually sail on the water, there is more design and construction involved. In particular, weight – both above and below the waterline. Will it be radio controlled etc ?
              Let us know what you're aiming to do with it.
              Regards,
              Dave C
              #93592
              Kev.W
                @kev-w
                From the photo's, I believe Jeremy is using planks of 1" x 12" pine in a 'bread & butter' construct.
