Hi Vernon
What size props and number of blades are you going to use?
If around 37mm 3 blade a few brushless motors may suit are 3639-750(600watts) and3648-850(900watts).
As you are running 3 motors that's 1800 to 2700 watts!!!!
As for ESC's 60Amp 2 to 4S( I use Hobbyking car one's(HK-60A SL)(no plumbing and very good low speed).
You will require 3 of these and 2 Y connectors to link up to the throttle channel!!!
With the program card very easy to setup.
Lipo batteries Zippy Compact 3300.3S.60C(288 grams each) (139 x 45 x 24mm).
If you use a good balance Lipo charger with a safety bag and DO NOT charge them un attended you should not have a problem.
Charging speed 3300 mah divide by 1000 = 3.3Amps max.
Note Hobbyking weights are with packaging, my weights are not, so it's what is going in the boat.
Hope this helps to start with!!!
PS If you look on the Hobbyking site under some of the motors you can download a data sheet which covers a large number of motors.
