Hi Manxman
Not sure how technical to do this. A brushless motor has 3 coils(windings) nominally connected together at one end like a "Y" , the other end of each coil comes out to give 3 wires. To make them work, you need to feed them with a pulse of electricity in rotation, ie 1,2,3,1,2,3 etc. the permenant magnet of the rotor( the moving bit) then chases the magnetic field produced by these coils which a arranged physically(mechanically) at an angle to each other(for 3 field coils 120 deg apart).
The clever bit of a brushless motor set up is the controller, it converts the dc battery voltage to 3 continious sets of pulses each out of step with each other, and can change the speed (repatition rate) of the pulses to give speed control of the motor. You can reverse these motors by swapping any 2 of the 3 connections over, but some controllers do that for you.
I have tried to stay away from ‘3 phase’ and ‘phase rotation’ analogies
. and this explanation is rather simplistic for the technophiles, but I hope it answers your question
Cheers Tom
