I was wondering if you had done it as well. I bought the kit recently and I think it would look good on the water. The superstructure doesn’t seem very heavy to me and there’s a fair bit of displacement, so I think it would work. (I’m currently finishing an Airfix HMS George V which sits at the waterline with six aa cells, radio etc.)
It seems to me that the biggest question is how to adapt the half bulkhead construction to hold the necessary parts. I’m thinking it would probably be best to cut the prop shaft slot before building and then use a router to cut through the keel piece from the inside once each piece is planked. On the bright side there should be some nice big hatches on top to get in through.
Regards, Grant.
