Yes Colin.
Easy to do but unfair to judge history and behavior by modern standards. The first time modern warfare really was understood was during the Spanish civil war where the opposing sides were assisted by other European military powers practicing for the real thing that sparked off in '38 and '39.
The German fleet escaped more extensive destruction by some measure of luck and to an extent failure of signal exchanges at quite junior ranks.
The telling factor was that despite the carnage and terrible losses on both sides, the British navy were able to sustain those losses better than the Germans who had a much smaller fleet. The German fleet was effectively sterilized and didn't put to sea again en masse until the move to Scapa Flow as part of the armistice reparations.
I have a very interesting book called "From Jutland to Junkyard" which chronicles the salvaging a large part of the scuttled fleet. Absolutely amazing how they accomplished this work. Ironically, a lot of the salvaged steel was sold back to Germany and movement of the hulks was assisted with German tugs. Hitler thought that bit was humiliating so put a stop to it.
It was a dark period with some unfortunate shootings and further deaths long after the war was over but the British mainly saw the scuttling as treachery. It is quite clear however that had the roles been reversed, the British Commanders would have done the same thing and described by their countrymen as patriots.
If you find the book, it is a great read.
Tim R
