Aziz tug water inlet
Home Forums Building Kits Aziz tug water inlet
  • #76070
    Stefan Fyfe
      @stefanfyfe50763
      Hi all,
      Haven't posted or done much work on the tug until now due to work commitments but I have made steady progress in the last few days.
      I have a Lucas type washer pump to run a fire monitor using 4mm tubing but I am struggling for where best to locate a water inlet and what to use?
      I had considered a plastic barb type fitting on the side of the hull below the water line but I wasn't sure If it should go on the bottom of the hull.
      The pump is self priming, I've tested it in the sink (please don't tell the wife) so doesn't need a scoop to get water into it.
      thanks in advance
      Stef
      Stefan Fyfe
        @stefanfyfe50763
        #76077
        Cookie
          @cookie15923
          Hi Stefan,I have bought 2 Lucas pumps and both failed after a short time so be aware , i replaced them with 2 from Model Boat Bits and have had no issues .
            Hello Stefan
            As the pump is self priming I would fit the inlet on the bottom of the hull using a fitting like the one shown below. Use a thin outer nut to make the inlet as flush as possible.
            Related image
            Hope this helps.
            Stefan Fyfe
              @stefanfyfe50763
              Thanks for the heads up on that Dave, might need to change that detail for one from model boat bits as you say.
              Paul, at the bottom of this link is what I had in mind. What's your thoughts on this?
              Thanks guys. That gives me something to go on.
              #76097
                Perfect
                #76098
                Cookie
                  @cookie15923
                  The issue was the lucas one was fine when pumping but if you attempt to run it dry for even seconds while testing they seize up , i tested mine when i bought then with a bowl of water out of the boat , but once installed in the boat i ran them just to check the wiring for seconds and they seized and game over , i have to say however they had a Lucas badge but were made in china ,
