Well, my kit arrived this morning and initial impressions are good.
The grp hull is robustly laid up with a good gelcoat finish with no air bubbles apparent.
I shall give the hull a float in the bath and load with ballast so that I can get an idea of the weight required to get down to the correct waterline.
By weighing all the other components, I should be able to assess what sort of weight I have available for battery selection.
Having done that, I shall start the build by constructing a building stand to get things level on the bench.
