Welcome to the forum Grumps.
Following on from Richard's suggestions, I think it would be a good idea to look at the Caldercraft Fineline range as they can accommodate a standard 4mm shaft in a 6mm outside diameter tube. This would give you much more choice with props.
Propshop propellers are generally held to be the best but are relatively expensive and delivery can sometimes take a while.
Raboesch do a wide range of nice props which would be quite adequate for your trawler.
Deans Marine alsao do a wide range of shafts and props including 6mm tubes with 4mm shafts.Well worth a browse.
You will find 3mm shafts and props at Cornwall Model Boats and Deans if you want to keep the existing tube and can find the sizes of shaft and prop you need.
Decisions!
