Another billings slo-mo-shun
Home Forums Building Kits Another billings slo-mo-shun
Viewing 25 posts - 151 through 175 (of 177 total)
  • #29552
      OK Phil…..Just checking
      There`s no rush at this time of year
      We`ve got the big freeze again, here in Manchester
      Phil Winks 1
        @philwinks1
        As I said Bob we’ve thankfully had a thaw since yesterday and outside temps currently about 6 degrees (positively summer like LOL) so hopefully tomorrow will see suitable weather.
        I’m going to charge the bty’s up and grease the prop shaft this afternoonready just in case.
        Phil
        #29672
        Phil Winks 1
          @philwinks1
          Well last weekend I got too busy, but this week, after good weather all week, I thought yes we’re on.
          So got all charged up and camera at the ready, arrived at the pond, and after the 1st cold snap in a fortnight last night, the ruddy ponds solid again dooh
          Keep on trying Philip LOL
          #29674
            We are frozen at this end too!
            Had a look at the garage gutter barrel and it`s split from top to bottom!
            Such is life!
            Phil Winks 1
              @philwinks1
              I just couldn’t believe it Bob we’ve had great weather for a fortnight and one little frost and its frozen again. and it was such a lovely day too quite warm in the sun.
              Phil
              #29941
                Any progress, phil?
                Len Ochiltree
                  @lenochiltree67043
                  Hi Bob,
                  What is the latest on your one ?.
                  Len.
                  #29944
                  Phil Winks 1
                    @philwinks1
                    Unfortunately Bob the weather and my spare time are in the habbit of not coinciding I’m afraid. Think I mentioned before the bath test was scary a less than half full bath and a quick run up to full throttle and the floor got just a little damp lol. on the plus side the ammeter only showed 8A so if the test is disappointing there’s the option of a bigger / courser prop as I have a max of 26A avaiable and this was on the lower voltage bty so more revs are available too.
                    Phil
                    #29945
                      Thanks for the latest info, Phil
                      Len…….No progress with my boat either……..Just gathering dust in the workroom
                      Waiting patiently in the wings, on the look out for the legendery brushed motors that will come up to scratch.
                      The brushless option is far too expensive at the moment
                      Thanks Phil
                        I have never set much store on the bath test for power consumption or thrust…they just are not big enough. Phil I dare say the 8A you saw was not fully representative of your slo-mo`s full potential, and as you say, the water goes everywhere.
                        It`s ok for smaller or lower powered models or to give a rough indication, sometimes.
                        I recon a test tank to give a better reading would have to be long and deep but who has the room or a wife willing to allocate that much garden for testing model boats.
                        Mind you, when I tested my SRN4 test vehicle for hovering capability (a grand name for something as bodgy as it was) I did it in a builders knocking up plastic tray thing with only 2″ of water!
                        Phil Winks 1
                          @philwinks1
                          Hi Bob and Ashley.
                          I find the static test in the bath produces the same results as a tethered test at the pondside. the water wasn’t spraying directly from the prop simply the stream of water running back down the length of the bath welled up towards the taps and some spilled over the side the water level in the other end visible dropped by nearly an inch or so and the push of the boat required a very firm hand to control
                          If I’d felt that level of push from a 1.5kg model back in my aeroplane days I would’ve been able to guarentee a flyer
                          So I really am confident that we’ll see good results when the good weather and my spare time finally coincide
                          Phil
                          #29952
                          Phil Winks 1
                            @philwinks1
                            Ok gents the time when good weather and my free time finally coincided and of to the pond I trotted with the old lady firmly tucked under my arm and a fresh 7.4v bty tucked inside her.
                            The results were pleasing although she does need trimming further forward and I wish I’d taken the 11.1v bty with me however watch the vid and judge for your selves.
                            She rides slightly nose high and could do with a tad more speed, However changing the bty to a 3s1p (11.1v) will most likely address these two issues in one move
                            On the whole though I’m well pleased she gets on the plane without fuss and although the stern is a little deep one can see air under the hull aft of the sponsons.
                            Needless to say I left the pond with a cheshire cat like grin
                            Phil
                            #29953
                              Phil. That looks really good, and although it may not be as fast as you would like, I think it is on the money as they say.
                              The trouble with model boats at speed, in my eyes, is that they start to “skip” and bounce unconvincingly over the non-scale water and waves and start to look like lightweight R-t-R types. Your vid shows old Slo-mo as being planted and fairly quick, or at least quick enough to look convincing.
                              You should be well happy with that.
                                  whoops !!
                                  #29956
                                    Well done, Phil…….Action at last!
                                    The motor doesn`t sound like a brushless type?……..It hasn`t got the familiar high pitched whine?………..Would a smaller prop get the revs up?
                                    Phil Winks 1
                                      @philwinks1
                                      thanks for the kind comments lads.
                                      Your right about it not needing much more speed Ashley however I would like to get her slightly more nose down when on the plane. otherwise yes I’m chuffed to bits with her.
                                      Bob my old mate that’s such a common misconception with brushless motors, every one expects that they rev their nuts off!
                                      agreed with the FE boy’s being the 1st in our hobby to employ them that’s the impression they give
                                      however this motor is relatively low revving at 900 rpm/V and that prop isn’t slowing it one jot such is the torque of these low kv motors
                                      hence my plan to up the bty from 7.4 to 11.1v that’s a 50% voltage increase and so a 50% rev increase in theory. in fact prob more like 40% as the poor old motor is only 93% efficient (as opposed to about 60 or 70% for a brushed motor)
                                      also the extra weight of the bigger bty will just about tip the nose down a touch getting her bum out of the water a bit more.
                                      And if that fails to get her level on the plane then a stepped hull modification is planned with a step of just 4mm, just forward of the prop.
                                      then hopefully the prop will run true surface and that will increase its efficiency and as a bonus produce the charicteristic rooster tail that the old lady was famous for. (at 178mph she had a 1/4 mile rooster tail containing an estimated 1/2 a ton of water in it)
                                      Phil
                                      #29959
                                        Hello Phil
                                        If the prop is not slowing one jot…..then try a bigger prop?
                                        Just a suggestion………Bob
                                        #29960
                                        Phil Winks 1
                                          @philwinks1
                                          Hi Bob
                                          a larger prop is another option after I’ve investigated the larger bty and then the minor mod to the hull. which incidently may take the form of small deflector plates either side of the external section of the prop shaft just to lift the stern at speed
                                          the advantage of not going larger on the prop is Amps currently there’s about 40 mins of bty life on this prop a larger one would increase the Amps and thus shorten sailing time and consequently the increased load on the bty will to some extent shorten its usable life re the number of recharges needed
                                          Phil
                                          #29979
                                          Phil Winks 1
                                            @philwinks1
                                            Just a quick report.
                                            I had some time off this morning and used some of it to try the bigger bty out,
                                            I’m pleased to report that the extra power and conseqent slight shift forward of the balance worked a treat there really is no need to develope her further.
                                            she is app 30% faster and the stern rises nicely so she is level on the plane.
                                            I did take the camera but wasn’t able to safely steer her and video at the same time.
                                            such is the extra speed that the size of the pond has become a problem taking just a few seconds to cover the 40yds or so of open water available..
                                            She still looks planted on the water and although faster she isn’t ridiculously so also some semblence of a rooster tail is evident at top speed, which adds greatly to the sense of realism.
                                            I will have some one with me on sunday who may be able to follow her with the video camera so I do hope to put a final video up then.
                                            Phil
                                            #29980
                                              Phil. This is a bit of a problem with fast boats, they cover so much water so quickly that the speed becomes a bit unusable except in short bursts.
                                              But what the hell, eh !!!!
                                              Phil Winks 1
                                                @philwinks1
                                                Too true Ashley
                                                now I want to take it up too burnham. Apex lake is about 200yds across and unsuprisingly the club there have a good number of fast electric models
                                                Phil
                                                #30076
                                                Phil Winks 1
                                                  @philwinks1
                                                  Finally got a vid of her on 3 cells for you all not the best quality really must invest in a decent camera.
                                                  Phil
                                                  #30077
                                                    Hello Phil
                                                    I`ve had a look at your video and your boat is going quite well. but it`s not exactly flying!
                                                    Sorry Phil….the motor should be whistling……..I know you`ve selected a slow revving motor for some strange reason. intentionally……and you are the expert
                                                    The motors at Bury Metro absolutely scream and howl beyond belief and jump across the wavelets and are airborne for about 2 metres at times!
                                                    That`s what I was hoping for on your model
                                                    Don`t take offence, old chap…..but you went to all that trouble making your model as light as a feather for a sparkling performance
                                                    But if you are happy….That`s all that matters!
                                                    Only my opinion, Phil………. Bob
                                                    #30078
                                                    Phil Winks 1
                                                      @philwinks1
                                                      No offence taken Bob but, if we go back through this thread I’m sure my intention from the off was to produce a scale model with scale performance and that roughly equates to 14mph now she’s prob well over that closer to 20 so aim achieved I’d say.
                                                      However the idea of making her exceed more than double scale speed has occoured to me and it would be a simply matter to fit the 3600kv (revsx 4 x as fast) version of this motor and do that however I would no longer be able to effectively sail her on that pond, and she would sit on the shelf except for 1 or two outings to apex and an outing to the river in tauton each year,
                                                      To be honest I like sailing her, and with this set up she’s going to pretty well live in the car during the summer, for impromptu trips to any bit of water I’m passing lol
                                                      Many thanks again for the model, she is already attracting great interest every time she goes out, and is responsible for at least one new member to our little club, and she’s only been out 3 times so far.
                                                      Phil
