The outlet is at the water line on the stb side towards the stern bob but if you hold her still and observe the cooling pipes its quite obvious that even at 1/4 throttle water flows quite fast and this is confirmed by holding her at a slight port list so the exit comes above the water line
Just a couple of points on the glue Bob do not get either on your hands! with the Cyano the real danger is accidently sticking your fingers to some thing or them selves. also if cyano gets damp it can get quite hot so have some water handy to cool your fingers should the worst happen. another issue with cyano is when set if you find yourself cutting/grinding/sanding it there is a point easily reached with a dremmel when it gets hot enough to vapourise. this rarely affects the joint but the sudden puff of smoke is not something you want to breathe or get in your eyes. trust me it hurts. As for Gorilla glue it has, as far as I know, no serious toxicity, but even while still wet will not wash of fingers. in fact the water simply speeds the set. it can however be removed with meths before it sets but not afterwards.
Edited By Phil Winks 1 on 19/07/2009 21:33:52
