Well what a lovely day its been barely a cloud in the sky and varnish has been drying in record time. starting at 5 this morning (to hot to sleep
) I’ve got 3 coats on the whole thing and fitted the deck fittings that I’ve made so far
I’ve also biten the bullet and reckoning there was enough varnish on I’ve given it a bath test. its weight at present is 5.125kg 11.3lbs and with the CoG set where you designed it Paul it sit 1/2″ above the chine at the stern to 1/4″ below at the bow. how does this sound to you should I add a little more weight do you think
I still have to upholster the seats and make a proper dash with dials etc buy the props and not forgetting a figure or two plus endless coats of varnish and one or two cosmectic fixes including that bit of missing venneer at the bow see last pic its under the chrome tape at present but all in all I think I’m well on target for proper water trials in July.
Edited By Phil Winks 1 on 24/05/2009 18:21:42
