The Caldercraft Fineline range is really intended for moderate speed operations. As the name suggests, the construction is relatively lightweight to reduce the outside diameter of the tube to give a scale appearance for scale models. For a performance model a beefier tube is needed.
However this model represents a fast sports boat rather than a racing craft and your video shows that it is running at well over scale speed.
If the bearings can't be replaced then you are faced with removing and replacing the tube. However it may be worth contacting Model Boat Bits
who offer a bespoke engineering service and would probably be able to make you a set of new bearings. If you can then extract the existing ones it will save you a lot of trouble but it would be wise to take the advice from Dave and Chris and use a less powerful motor/prop setup. This should still give impressive performance.
It might also be worth contacting Jotika/Caldercraft to see if they could supply you with replacement bearings although these might be relatively light duty ones compared with bespoke ones.
Presumably you can access the outer bearing reasonably easily. If you can get that out then it should be possible to insert a rod or dowel into the tube to drive out the inner one.
If the tube does have to come out then the best method is usually to apply heat which will break the glue joint so that you can twist the tube and extract it. A heavy duty soldering iron will do the job. The biggest problen with getting the tube out is that you need to do it without damaging the rest of the model or the varnish/paint finish.
All things are possible though!
Edited By Colin Bishop on 02/01/2019 18:27:36
