Hi Folks …I have just acqured a nearly built Moonbeam ..the problem is the ballast . When I received it through the post, the ballast was rattling about…so probably caused by transport. Never mind.
She is c. 130cm long, and should wigh c. 8.1 kg ? I initially weighed it at c. 7.1kg , then removed the ballast with a small Dyson , and now have presently c. 3.1 kg of lead 'SHAVINGS'
THE EMPTY VASSEL NOW WEIGHS 3.9KG ,so into the very unaccesible long keel I have to add c. 4.2kg ..since the deck is already fitted, and there are 2/3 stringers epoxied in. I can JUST GET MY HAND INTO THE MIDDLE HATCH SPACE.
I am thinking of maybe using small freezer bags, and pushing them in , after brushing in some epoxy onto the hull keel space.
But any advice would be tremendous !! Many thanks.
