6ex 2.4gig
6ex 2.4gig
Home Forums R/C & Accessories 6ex 2.4gig
  • #16785
    subhunter
      @subhunter
      dear all, hope someone can help!!!Have just had my 6ex futaba tx exchanged for a safe one with all the correct stickers on the bottom,now the existing recievers wont go solid green and work at all as they did with the old tx i sent back…the recievers x 2 are r606fs 6 channel easy link that change from solid red to flashing green when switched on after the transmitter so have i been given a rogue tranny or am i not doing it right ? can’t see any recessed set up button on recievers Thanks in advance Roger
      Ian Kennedy
        @iankennedy31889
        Hi Roger,
        If you have the receiver aerials facing you, the rest/bind button is a small rectangular button between the two wires set at the split line of the case.
        Good luck and i hope this helps
        Ian
        #16792
        subhunter
          @subhunter
          Ian your a star,didn’t know there was a set up button on the receivers,all is working now thanks for that all the best Roger
          #16797
          Ian Kennedy
            @iankennedy31889
            No problem,
            We are here to help !!
            Ian
            #5003
            subhunter
              @subhunter
              setting up
