WHICH ADHESIVE
WHICH ADHESIVE
Home Forums Beginners WHICH ADHESIVE
  • #18838
    Geoff Bird
      @geoffbird11926
      Hello Folks. Which adhesive should I use for attaching timber rubbing strakes to a fibre glass hull. Geoff
      Geoff Bird
        @geoffbird11926
        TIMBER TO FIBRE GLASS
        #18843
          A good epoxy resin should do the job but whatever you use be sure to abrade the area where the wood will attach as, once it has cured ,any bond to glassfibre will essentially be a mechanical one.
          Dr John Booth
            @drjohnbooth43899
            Hi Geoff
            As Colin says any good epoxy such as Araldite is perfect for the job, is there any way that you could get a mechanical fix, like a screw, into the rubbing strakes from inside the hull as this will help the glue to stay bonded to both surfaces.
            John
            #18854
            David Wooley
              @davidwooley82563
              The method  that has been quite useful  is to “pin”  the strake to the hull.
              then bond the pins into place within the hull . You could drill a  a series of small holes into the back of the timber strake , insert the pins and locate them to the hull .bonding with fibre glass or epoxy  resin.  This gives a strong an durable fix.
              Dave Wooley
