water cooled speed controler
Home Forums Beginners water cooled speed controler
  • #19639
    Brian Morris
      @brianmorris30448
      building the shamrock (model slipway ) i have a watercooled speed controller , does it need a pump and also where do i put the water scoop? thanks
      Brian Morris
        @brianmorris30448
        #19654
          Hi Brian
          What make of speed controller is it?
          Brian Morris
            @brianmorris30448
            ripmax sea sprint p-xtra
            #19709
            Mike Davidson
              @mikedavidson22772
              Hi Brian most ESC’s today are claimed to be waterproof, but if cooling is required, a fair flow of water through the heat exchanger will be required, therefore, I would put a scoop down through the hull, and an exhaust on the transom so that a through flow is not impeded in any way. some correspondents claim that their ESC’s run hot, and that will not help. I guess that to be kind, you don’t make the ESC do too much work by fitting too high voltage battery, and remember the maker fitted it with water cooling for a reason, so my thoughts are that if you do cool it, it will notsustain heat damage and reward you with many years faithful service……………………………………………Mike Davidson…………..
              #19711
                Hi Brian
                ESCs do run hot and as yours is water cooled I would think that it will need a constant flow of water so I would imagine that a pump will be required however I suggest that you check with ripmax.
                  I’ve just seen the Tech Spec of this thing and you would probably need a 10-turn motor running from 16 cells to make it even break sweat. 280A continuous current? Who are they kidding? Even on 12v that’s more power than my workshop fan-heater uses at full blast!
                  I have more than a slight acquaintance with Shamrock and you won’t need anything more powerful than a Speed 600 ECO on 6 cells. Trust me. I wouldn’t worry about water-cooling the ESC, mate.
                  Edited By Dave Milbourn on 24/03/2009 23:35:33
                  #19721
                    Brian, I think that unless yours is a go-fast, then a scoop arrangment will not provide a good continuous water flow and so a pump is the safe bet. Shame you couldnt cut a small hatch in the bottom of the hull and glue the ESC into it and then you would have permanent water cooling !   or is that an idea too far????    Ashley
                    #19739
                    Brian Morris
                      @brianmorris30448
                      thanks for all your sugestions , i have a windscreen washer pump spare so i may as well fit it , it may also look perhaps more realistic!!
                      #19741
                      60watt
                        @60watt
                        Brian,while your esc would need watercooling with a 700bb turbo on 12 cells it wouldn’t  in most racing classes.Your esc will cut out if it overheats,which I doubt will happen.
                        Watercooling was needed when fast electric boats used small high frequency at 40+ amps or where linear bec was used with 20 cells..The resultant losses in a small package required forced cooling.
                        You put a bent scoop inlet close to the prop or one  the underside of the hull or sponson and that pressure differential does the pumping for you. Googling for other fast-electric foruum posts and pictures will show you how it is done.
