Hi
Have a look at the D3548/4 1100KV 910watt motor which will run on 3S to 5S batteries.
If you get an ESC with reverse which will handle 3s to 5S.
This will give a fair amount of play room for the speed you require.
Battery Turnigy 5800mah.3S.25C(475grams) will get you about 3/4 hour.
The higher the C the more current you have on tap.
Prop start with plastic because cheap, so you can have a good range to experiment with, metal props can get pricey.
I got a few from Hobbyking for my 1100 kv motor ,38mm and 40mm 2 bladed pitch 1.4.
I just received a 40mm x 1.4 pitch metal one which I installed on my boat and will test.
