Timing belt drives are similar the gear drives…..Teeth meshing with teeth
There's no problem with two pulleys and a belt
But the Abell drives can have clashing teeth
Two belt drives driving one final pulley is the culprit!
When the second belt drives the same pinion, the first belt may be just in advance and try to do all the work
In other words, the drive will keep jumping from one motor to the other
We are only talking vibration…..So by having a bit of slop in the grub screw drive dogs, the belts will have room to manoeuvre……..Back and forth slightly
It must be a strange sort of drive train, where the drive comes from two sources
I hope you agree with this cock and bull story……lol
