Gareth cc Dave, Paul
a wonderful technical response that all falls apart because of the first statement , "If you assume"
Most assumptions are simply opinion so that is not a good basis to argue from. However, it does remain a fact that, with any marine or aviation propeller, not all the thrust is parallel to the shaft line. There is also an amount of thrust in an outward direction ( centrifugal force ) that is not taken into account in your calculations. Neither is the rotational force induced in water or air by a spinning propeller.
I am not saying that your conclusion is either correct or incorrect, just that it has been reached with less than perfect mathematical methodology
To be convincing in any way, I would suggest that you demonstrate a far more accurate and realistic model of performance given by a propeller. It would only be correct for a stated size and pitch, but would be a starting point for sensible discussion. That would seem a better course of action than just putting down ideas for the simple reason that there is disagreement
Let's see some proof either way.
Ref Fairey pics, the shafts are at that angle because " They couldn't fit then in any other way ! Unless there is documentation to the contrary ??
Mike ( I can take any amount of sniping from those nasty men !
Edited By lnvisibleman on 18/09/2014 00:28:21
Edited By lnvisibleman on 18/09/2014 00:30:05
Edited By lnvisibleman on 18/09/2014 00:31:58
