Dear All
Getting away from Bobs problems with his AbellDrive we will stagger back to the theme of this thread and hopefully, for the members who have requested the drawings, get on with the build.
The first and possibly most important task is to locate a suitable building board for this project, the building board must be large enough to accommodate the layout schematic (drawing no 00)be flat, level and rigid enough not to bend or warp during the build.
The layout drawing shows the centre line and full extent of each frame so all you have to do is position each part over its corresponding location.
I have started the build from the Transom but it doesn't really matter which end you start from.
Each of the frames is fixed to the building board with a batten (drilled and screwed to both the frame and building board) using the centre line for guidance.
Edited By Paul T on 11/07/2014 15:29:17
