Its me once again, and so soon!!
I have had a wiring diagram produced for me by Dave Milbourne at Action Electronics (as I may have mentioned before), which uses a 12v 12ah battery to power everything – the rc equipment, lights, sound, smoke generator & fan.
My problem is that this size of battery is quite a lump, and in fact wont fit through the opening in the deck. Even if it did, it’s a bit high for my liking (need to keep the weight in the boat low down as poss.).
So, I’ve decided I’ll buy two 12v 7ah batteries, which are much narrower, and can be laid flat one next to the other.
My questions are: how do you conect the two batteries to maintain 12v (and not 24v), and will I need to disconnect both batteries to charge them (I ask this because one of the batteries will be slid up the front of the boat, and I dont really want to get it out when they need charging).
Many thanks, Paul
