Went out to play at a concert last night, 5.45pm, and it took at least 15mins to defrost the car so it was safe to drive. Coming home at 9.30pm, 10 mins wait.
This morning it looks like the car has been sprayed with white paint.
No boating methinks. Pond must have 1/2 inch of ice on it and it would take me longer to de-ice the car than the drive to the pond!
matted clear acrylic squares need gluing into Terry’s window spaces. A tricky feat as if I get glue on the edges I reckon it will show up when they are backlit. Not sure how to proceed. I may smear glue on the frame inner and carefully position the window? Ideally I need a transparent glue in a dispenser with a fine tip to apply a thin bead around the edges. I have some acrylic glue that dries crystal clear and this will wipe off with a damp cloth nicely and may be the way to go.
As it is, the Matt windows may not provide the right look when on the pond unless the backlight is strong enough to be seen, and I may end up painting the inside of the windows white?
