Hi Bob
Thanks for the prompt and to answer a few obvious questions about the props.
No they aren't injection mouldings, they have been machined from high tensile Nylon 66
They haven't been handed because I didn't want to spend the computer time designing a handed version.
They look like computer cooling fans because that is where the inspiration for the design came from but the pitch and camber of the blades is different.
The central boss is so big because the calculations indicate that these type of blades operate better with a 'dead area' in the centre of the rotating area.
The circular indentations in each unit are the results of the units being balanced.
I hope this helps answer a few questions that the readership might have but if anyone has any technical questions I will be happy to answer them.
Regarding your question about chain drive …there is no need to change the ratio as the props are designed to be fully effective operating on direct drive.
Edited By Paul T on 14/07/2014 14:56:32
