Posted by ashley needham on 02/10/2014 19:17:11:
AmyJ. Please elucidate on your enigmatic post. Perhaps our jargon does not translate into antipodean that well.
Paul certainly does not have designers block. i suspect he has a dose of input overload ! This is normally cured by a reality price check,as Gareth has found out….
Elucidate? Are you asking me out on an elucive date? If so I might give you a vauge reply, some day (possibly).
Translation:
O my gosh. What the…? You've got to be joking….. Why?
Elucidation:
Why would you want or need a model with a 170 kg static thrust? If you want to pull the stern out of some one's boat, the car would do it better and cheaper.
What 12 ton vessel is going to be towed around the model boat pond, and for what purpose? BTW 50 kg thrust will pull and 12ton boat happily, if not windy or tide running ( A 2hp outboard gives about 50 kg and will move our 40' launch along, all be it slowly. 3 such out boards will shift a 50' yacht against a reasonable wind and tide)
If one had to have such a model, I say, (with the supreme arrogance of antipodean youth) that it could be achieved much more cheaply and simply than what is being proposed here! (hence my challenge of a virtual build – I have no use for such a boat!) I realise I should have put my challenge on this thread, not the vintage cruiser one , whoops.
Having said all that , I'm enjoying this thread, the inventiveness and banter etc.
Any how that's my opinion, You are all most welcome to tell me I'm full of it!
Aj
